TURCK Expands Offering of FM Approved Sensor-Cordset Combinations
By Design World Staff | May 15, 2009
Minneapolis, MN– TURCK has expanded its offering of FM approved 12, 18 and 30 mm 3-wire DC barrel sensor and cordset combinations. Now, quick disconnect sensors may be used in Class I, Division 2, Groups A, B, C and D environments when equipped with a TURCK lokfast™ guard. TURCK sensors with potted-in cable for use with conduit are also FM approved for these locations.
TURCK’s lokfast guards render quick disconnections not “normally arcing” by eliminating access to the coupling nut and requiring a tool for removal. The ability to use quick disconnect technology enables customers to install sensors faster and at a lower installed cost than traditional conduit methods. All TURCK sensors that carry FM approval also carry IEC IP 68 degree of protection.
TURCK’s ITC rated M12 eurofast® or 7/8 16UN minifast® connectors and cable are also FM approved when used with the lokfast guard.
TURCK
www.turck.us
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
