    • Subscribe!
TURCK MZB Series Zener Diode Barriers
By Design World Staff | September 28, 2009
Minneapolis, MN – TURCK introduces MZB series Zener diode barriers, designed to effectively limit excess energy before it reaches a hazardous area. The MZB barriers provide convenient removable terminals within an extremely efficient and space-saving design–with channels as small as 6.3mm wide–to consume minimal panel space. Additionally, the MZB series features a bussed power feed and offers both relay and solid-state switch models.
Each channel of the new MZB Zener diode barriers is fitted with two stages of pulse-tested Zener diodes and an infallible terminating resistor. If an electrical fault such as an overvoltage occurs in the non-hazardous area of the barrier, the Zener diodes limit the voltage available to hazardous area circuits, while the series resistance limits the current. Within this circuit is a fuse designed to immediately and safely rupture if the excess energy continuously applied to the barrier exceeds the design criteria for the loop.
TURCK
www.turck.us
Filed Under: Factory automation, Safety systems + components, Test + measurement • test equipment
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
