An overmolded face eliminates the need for an additional sealing gasket, ensuring optimal performance in harsh environments, such as wind turbine nacelles. The cordsets feature a translucent molding material with embedded, bright LED’s, and provide superior visibility for power indication from any angle with black, grey, yellow, and clear coloring options to accommodate diverse applications.
The overmolded design offers a full cordset alternative to traditional field wireable connectors, which require assembling and hand wiring before they can be used. Field wireable configurations increase the chances of mis-wiring, and also incur high labor costs. TURCK overmolded valve cordsets provide a completely assembled solution that is 100% factory tested and ready to use for fast, easy implementation.
Solenoid valves control the flow of gas or liquid in cylinders, fluid power motors, and larger industrial valves. These cordsets also meet NEMA 1, 3, 4, 6P and IEC IP67 standards.
TURCK
www.turck.com
Filed Under: Green engineering • renewable energy • sustainability
