    • Subscribe!
TURCK Sensors Provide Accurate Valve Monitoring on Rotary Actuators
By Stacy Combest | August 28, 2013
TURCK announces its new line of inductive angle sensors for rotary actuators. Operating with the inductive resonant circuit measuring principle, these inductive angle sensors deliver enhanced valve monitoring on rotary actuators. The sensors are designed with an innovative open face design, providing analog or discrete outputs and flexible mounting options.
TURCK inductive angle sensors are able to monitor three-way valves, while also detecting the valve position during cleaning cycles. Additionally, the sensors are capable of detecting the wear of seals, saving downtime from seals that are worn from switching cycles. For flexible operation, the sensors are available in two models, either with two programmable PNP switching outputs or with two scalable analog outputs of 0…10V and 4…20mA.
Featuring a protection rating of IP67 and a rugged, compact housing design, the inductive angle sensors provide a wear-free sensing solution in harsh applications. The sensors provide optimal performance in temperatures ranging from -25 to 75 degrees Celsius, making them suitable for a wide range of applications including valve automation, steering position feedback and dancer arm control.
TURCK
www.turck.us
Sensor Tips
Filed Under: Sensor Tips
Tagged With: TURCK
Endress+Hauser launches new sensors and holder assembly
What metrics can bioelectrical impedance analysis provide? Pt 2.
What is 3D scanning?
    • Subscribe!
