Minneapolis, Minn. – TURCK introduces its new 4-wire PROFINET cordset line, developed to provide plug-and-play connectivity for applications using PROFINET protocols. PROFINET, the fastest industrial Ethernet I/O network, is compatible with existing fieldbus systems and the only network that can accomplish a line topology–especially ideal for long conveyor systems. These cordsets connect to TURCK’s BL67 Ethernet gateways for PROFINET–which can be connected to up to 32 I/O modules per gateway–to allow smooth integration into current fieldbus structures.
The PROFINET cordset line offers both M12 Ethernet D-coded and RJ45 connector options, allowing users the option to mix-and-match any connector combination to meet unique application needs. Cordsets are also available with color-coded field wireables to convert hard wiring to quick disconnect.
TURCK’s PROFINET cordset includes cable that meets IEC 11801:2002 Cat 5 and TIA 568B: 2001 Cat 5e requirements. Like most TURCK cordsets, the PROFINET line offers standard and custom lengths, as well as pigtail or extension cordset options.
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways
