TURCK’s 7/8-16UN Minifast Receptacle
By Patrick Curran | February 11, 2010
Minneapolis, MN — TURCK announces the new 7/8-16UN minifast® explosion-proof feed-through receptacle, which is CSA certified as a secondary conduit seal. This quick-disconnect solution can serve as a secondary conduit seal to prevent gas migration or as a boundary seal, when used with a TURCK CSA certified cordset. The receptacle may be applied in Class I, Division 2 locations without the use of intrinsically safe circuits or in Class I, Division 1 locations with intrinsically safe circuits.
TURCK-minifast-receptacle
Fully potted in a durable 316 stainless steel housing, the explosion-proof feed-through receptacle is designed to withstand 2,000 psi of pressure. It also provides IEC IP67 protection against liquid ingress when a mating connector is attached. The receptacle installs directly into 1/2-14NPT threaded conduit entries and is rated for 600 V and 9 A. When used as a secondary conduit seal, the receptacle is limited to 30 V and 600 mA.
TURCK
www.turck.us
Filed Under: ASSEMBLY, AUTOMATION, Connectors (electrical) • crimp technologies
