TURCK’s New BL20 Motor Starter Module
By Design World Staff | October 13, 2008
Minneapolis, Minn.
‚—TURCK‚’s new BL20 motor starter economy module utilizes SWIRE technology to provide daisy-chain connection from a single I/O slice to each motor starter via a ribbon cable.
The BL20 motor starter module allows 3-phase motor control to be connected to the same rack as standard I/O. In addition, with the SWIRE connection, motor starters can be mounted on separate DIN-rails within the same panel‚—pairing the flexibility of standard motor starters with the advantages of fieldbus control. ‚“When motor starters are on a fieldbus, the benefit is that they can be located close to the motor they are controlling,‚” Clute adds.
The BL20 motor starter module is available in sizes ranging from .08 to 20 horsepower, both direct and reversing, for use on DeviceNet‚â„¢, PROFIBUS‚®, CANopen, EtherNet/IP‚â„¢ and Modbus TCP/IP networks with both standard and programmable gateways. Trip indication may also be added to any motor starter. The BL20 motor starter module complies with industrial switchgears standards IEC/EN 60947-4-1 and carries an IP 20 environmental protection rating.
As the latest addition to TURCK‚’s expansive selection of industrial networking solutions, the BL20 motor starter module with SWIRE technology consists of a gateway, base modules and electronic modules. I/O modules are configured independently from the fieldbus protocol, and up to 72 I/O modules may be connected to a gateway, facilitating systems that may include up to 1,152 digital I/O points or 288 analog channels. All BL20 gateways are compatible with TURCK‚’s I/Oassistant software package, developed to perform initial configuration, parameter set-up, documentation, commissioning and diagnostic functions for on/offline usage.
www.turck.us
Filed Under: I/O modules, Connectors (electrical) • crimp technologies, ELECTRONICS • ELECTRICAL
