“Live-roller conveyor is old technology with many weaknesses compared to recent advances in plastic chain and belt,” said Mike Suter, VP for Regal Power Transmission Solutions. “Live-roller is noisy with pinch points from day one, and gradually turns into a downtime and maintenance problem with dead zones, belt wear, tracking and replacement, and complex snub roller center drives.”
With a turnkey retrofit program, you can convert a live-roller system, making economical use of the existing conveyor frame while adding new components that reduce product damage, part count, maintenance, downtime, noise and energy consumption.
This turnkey retrofit program transforms live-roller conveyor for sustainable, high-uptime performance. It combines the System Plast modular plastic belt and chain, high-efficiency Hub City or Grove Gear drives and Sealmaster material handling bearings. The variety of conveying surfaces available from System Plast creates options for every material handling need from single bottles to cases, people and even cars.
The System Plast includes a variety of conveyor belt and chain for low-maintenance, high-efficiency performance, using proprietary polymer formulations to suit application requirements. System Plast 2253RT roller top belt, for example, simplifies conveyor design and installation with its independently controlled moving surface that easily handles large or small, flat-bottom products, moving them on 1⁄2-in. (12.5 mm) balls spaced on 1-in. (25.4 mm) centers. It supports loads up to 617 lb/ft (9,000 Nm/m) or 1.1 lb/ball (0.5 kg/ball). The belt’s non-contact product manipulation eliminates impact and abrasion damage from pushers, as well as the need for mechanical adjustment or changeovers for conventional diverters or guides.
System Plast heavy duty and extra heavy duty plastic belts provide a non-skid, energy efficient conveyor surface for moving walkways, automotive assembly lines, car washes, and general material handling of heavy loads, such as barrels, drums, kegs and pallets. These strong and tough 2-in. (50.8 mm) pitch belts are currently used on automotive assembly lines in Europe. The belts handle loads up to 5,400 lb/ft and 7,800 lb/ft (80 kN/m and 115 kN/m) respectively. Both styles suit moving assembly line floors where the belt’s non-skid, solid surface protects against slips and prevents tools and small parts from being trapped. The belt’s design allows pusher bars to be attached, removed or replaced by a user at any time without disassembly of the belt, using molded-in drilling locators. Both belts use a patent-pending retention clip for the hinge pin. It can be installed or removed from either side of the belt with simple tools, as well as re-used. The molded-in, non-skid surface of hexagonal dimples is ideal for people movers, offering a high coefficient of slip resistance under oily or dry conditions.
Hub City High Efficiency Right Angle (HERA) reducers provide 90% efficiency in all ratios for up to 40% reduction in energy requirements. Torque-dense with double the capacity of worm drives, HERA drives reduce motor size requirements, as well as the physical size of the drive package. These reducers save up to $550 per year with each increment of motor horsepower for rapid payback, and they are warranted for three years. Wide torque capacity and modular shaft, base and flange components allow four sizes of the reducers to interchange with worm reducers from 1.75 in. (44.45 mm) to 6 in. (152.4 mm) center distance, reducing inventory requirements. Maximum torque ratings for the four sizes are 1,100, 2,600, 4,500 and 8,500 in.-lbs (124 Nm to 960 Nm). The smallest and largest HERA reducers are available in stainless steel, and packaged drives with Marathon or LEESON motors are available as well.
Grove Gear Bravo gear reducers feature a lightweight, single-piece aluminum housing that is vent-free and protected with high-temperature nitrile output seals. Bravo reducers weigh as much as two-thirds less and are one-third smaller than cast-iron designs. Interchangeable with drives commonly found in material handling and packaging systems, Bravo reducers handle frequent reversing and start-stop cycles with oversized high-speed bearings and a bronze alloy worm gear centrifugally cast onto an iron hub for maximum strength and lubricity. With IEC motor inputs and metric outputs, these drives can be replacements for other material handling reducers. Five sizes are available in ratings to 7.5 hp (5.6 kW) and ratios from 7:1 to 70:1, with center distances from 1.18 in. (29.9 mm) through 3.35 in. (85 mm). They are also available as integrated drives with Marathon or LEESON.
Sealmaster material handling bearings have features to provide years of maintenance-free performance. Available in pillow block, tapped base pillow block, flanged and wide-slot take-up housings, all of them start with a solid cast iron base or housing for improved stability and resistance to shock and vibration. A standard contact nitrile rubber seal helps keep contamination out and facilitates grease purge, and an auxiliary flinger helps protect the seal from direct contamination. Both SKWEZLOC and setscrew locking styles are available, and optional snap-on end caps for an extra level of personal protection from rotating shafts. Zone hardening of the inner race improves lock reliability by reducing distortion at setscrew locations.
RegalPTS.com
Filed Under: TECHNOLOGIES + PRODUCTS, Conveyors
