Two-Armed 3D Printing
By European Space Agency | April 4, 2019
Twin robotic arms work together as part of a project to construct what will be the largest, most complex object ever 3D printed in titanium: a test version of the 3-m diameter ‘optic bench’ at the heart of ESA’s Athena X-ray observatory.
The first multi-axis robotic arm builds up each new layer of metal using a laser to melt titanium powder. The second robotic arm then immediately cuts away any imperfections using a cryogenically cooled milling tool. The bench itself is placed on a slowly moving 3.4-m diameter turntable.
“ESA has teamed up with Germany’s Fraunhofer Institute for Material and Beam Technology for this exploratory activity,” explains ESA materials and processes engineer Johannes Gumpinger. “The final design of Athena’s optic bench is still to be decided, but if it will be built in titanium then its size and complexity is such that it could not be built in any other way.”
Due to launch in 2031, ESA’s Athena mission will probe 10 to 100 times deeper into the cosmos than previous X-ray missions, to observe the very hottest, high-energy celestial objects.
The mission requires entirely new X-ray optics technology, with stacks of ‘mirror modules’ arranged carefully to capture and focus high-energy X-rays.
The optic bench aligns and secures around 750 mirror modules in a complex structure with many deep pockets that tapers out to a maximum height of 30 cm. Its overall shape needs to be precise down to a scale of a few tens of micrometres – or thousandths of a centimetre.
“The optic bench’s complexity requires each addition to be milled immediately after printing,” comments André Seidel, overseeing the project at the Fraunhofer Institute for Material and Beam Technology. “Any subsequent modification could risk introducing contamination, weakening the space-quality titanium.
“Similarly, the entire process has been designed to minimise any risk of contamination. The titanium powder is swept into the laser using the noble gas argon that also prevents any contamination with air. And the milling tool is kept cool using liquid carbon dioxide that evaporates as it warms up, preventing any harmful deposition on the freshly-laid metal surface.”
Precision sensors immediately detect any out of tolerance elements for milling or more extensive repair – including milling away for reprinting.
Smaller segments have been manufactured so far, with a 1.5-m diameter demonstrator optic bench set to follow. The full scale 3-m bench is expected to take about a year to produce.
“It will be a huge task, taking a lot of time and energy,” adds Johannes. “But if we manage it, it will be the largest titanium object ever 3D printed – and the process will be available to manufacture other large parts, potentially in other metals.”
The project is being supported through ESA’s Technology Development Element as part of the Agency’s Advanced Manufacturing initiative, harnessing novel materials and processes for the space sector.
Last month more than 150 experts from all across Europe met at ESA’s technical heart in the Netherlands to share the latest results from ESA Advanced Manufacturing projects covering topics including 3D printing and the latest composite materials as well as friction stir-welding.
Filed Under: 3D printing • additive manufacturing • stereolithography, Rapid prototyping
PCB mills
September 2020 Special Edition: 2020 Additive Manufacturing Handbook
The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
Top 3 reasons why you should consider additive manufacturing today for production parts
