    • Subscribe!
Two Fieldbus Channels in Just One PCI Slot
By Frank Tobe | July 29, 2014
HilscherHilscher’s cifX 2-channel PCI card supports two independent Fieldbus communication channels in just one PCI slot. The 2-channel cards provide significant advantages, especially in applications where the number of PCI slots is limited, such as in compact box-type PCs and embedded computers.
The user can choose from any of the leading Fieldbus systems: PROFIBUS, CANopen, and DeviceNet. Models are available for two PROFIBUS channels, two DeviceNet channels, and two CANopen channels, as well as all combinations: PROFIBUS and DeviceNet; PROFIBUS and CANopen; and CANopen and DeviceNet. Due to loadable firmware and software licenses, the same hardware can alternatively be used as Double-Master or as Double-Slave.
Common to all of the cards is an extended temperature range from -20° C to +70° C, as well as a reliable address allocation at the PCI bus via a rotary switch.
All 2-Channel cifX cards use the same application interface and data exchange will be done via Dual-Port-Memory or DMA. A complete software package is included in the scope of delivery.
Hilscher
www.hilscher.com/usa
Filed Under: TECHNOLOGIES + PRODUCTS, Networks • connectivity • fieldbuses
Tagged With: hilscher
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
Ethernet remote I/O modules add Conditional Logic Computing
Self-contained actuator for a variety of applications
    • Subscribe!
