Norstat now offers a two-hand control panel specifically designed for dangerous work processes such as punching or pressing applications.
The PCB3 series of two-hand Control Panels utilize a durable smelted aluminum cover with protection lids over each pushbutton for added safety. The PCB3/SD comes equipped with an E-stop button and two reserved 50-mm holes for actuator buttons. The PCB3/S adds the 2 push buttons and the PCB3/P adds 4 additional 22.5-mm reserved holes along with the 2 pushbuttons and E-stop.
Also available are the TST zero force hand sensor buttons, with their low activation force and ergonomic design, they play a significant part in reducing the possibility of repetition injuries.
The PCB3 series utilizes a 2-mm rubber seal to protect the terminals against dust, oil and water and carries a protection rating of IP54 or IP65 (with supplied pushbuttons). A telescoping stand with a metal, pre-drilled baseplate is also available as an option. It includes two telescoping tubes of 70 mm and 80 mm with a lever to fix the selected height.
Norstat
www.norstat.com
You may also like:
Filed Under: Cabinets • enclosures • control panels
