Two-Part Anaerobic Threadlocker from Henkel
By Design World Staff | November 3, 2008
Rocky Hill, Conn. ‚— For use on threaded fasteners located on food- and beverage-processing equipment, Henkel Corporation (http://www.henkelna.com) has introduced Loctite(R) 2046(TM), a medium strength, removable two-part anaerobic threadlocker that fully complies with the Federal Food, Drug, and Cosmetic Act and with all applicable food additive regulations including 21 C.F.R. 175.300.
Loctite(R) 2046(TM) is a two-part, room temperature-curing anaerobic adhesive designed to lock and seal threaded fasteners, ensuring properly secured hardware and improved equipment reliability. Once cured, this adhesive prevents the growth of bacteria between a fastener‚’s threads. Uniquely, Loctite(R) 2046(TM) also eliminates possible problems associated with adhesive migration and contamination by curing at the fillet where a small amount of adhesive is exposed to air.
High viscosity Loctite(R) 2046(TM) is suitable for use on both fine and coarse threads. As it withstands temperatures up to 400 degrees F and endures the rigors of daily wash-downs, this threadlocker can be used in industrial deep-frying applications. Loctite(R) 2046(TM) requires no primer when used on stainless steel equipment and can be disassembled with standard hand tools.
This breakthrough threadlocker can be used to prevent loosening of fluid filler valve head cover bolts; thread stripping; or fastener rusting, galling and seizing. The unique two-component system includes three mixing tips that ensure proper proportions and full-cure characteristics. Additional mixing tips are available in bags of 10.
www.henkelna.com/mronew
Filed Under: Fastening + joining, Adhesives • epoxies
