    • Subscribe!
Two-Spoked Flat-Faced Handwheels with Retractable Handle from J.W. Winco
By Design World Staff | June 18, 2010
NEW BERLIN, WI — J. W. Winco, Inc. now offers GN 924.3 Two-Spoked Flat-Faced Handwheels with Retractable Handle.
JW-Winco-Two-Spoked_Flat-Faced_Handwheel
The handwheels are RoHS compliant and come in both inch and metric sizes. They are distinguished by their modern, flat-faced design and recessed handles. The handwheel body is pressure die-cast aluminum with a powder coated matte black pebble finish or a silver textured finish. Rim is concentric and square to bore. The locking retractable handle has a zinc plated steel threaded spindle, a black oxide steel retracting mechanism and matte black nylon plastic hand piece. The removable plastic cover shrouds the assembly hardware such as screws and countersunk washers, as well as the shaft end.
When the handle is pulled upward into operating position, it locks into a conical recess. To fold it down, draw the handle back from the recess and lay it down into the neutral position inside the handwheel spoke. A compression spring holds the handle in both positions.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Factory automation, Fastening + joining • locks • latches • pins
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
