UL-listed NEMA 4X polycarbonate enclosure billed as largest on the market
By Lee Teschler | June 19, 2017
The ARCA IEC from Fibox is said to be the largest UL-listed NEMA 4X Polycarbonate Enclosure. Made in the European IEC standard sizes, this enclosure is available up to 31.5x 23.5 11.5 in. The ARCA IEC cabinet enclosure is made of impact-resistant polycarbonate and will not dent, rust, crack or bloom like steel or fiberglass. It also is easier to modify and weighs less than either steel or fiberglass enclosures.
The stylish European design makes the ARCA IEC a good candidate for highly visible areas in industrial ARCA IEC and commercial applications.
The ARCA IEC Series enclosures are designed to accommodate electrical, electronic, instrumentation and mechanical controls indoors and outdoors where watertight, UV, corrosion and chemical resistant enclosures are needed, providing superior protection against extended UV, windblown dust and rain, splashing and hose-directed water.
The ARCA IEC is available with either landscape or portrait orientation.
More info: www.fiboxusa.com
Filed Under: Cabinets • enclosures • control panels • DIN rail
Tagged With: fibox
