WAGO’s universal surface mount PCB solution—the 2059, is now approved for 20 AWG/0.5 mm² conductors. 2059 terminal blocks create compact connections providing the perfect tool to minimize the size of LED modules. Featuring:
• A low profile of just 2.7 mm, minimizing on-board shadowing
• Wire cross-sections from 26 – 20 AWG (0.14 mm² to 0.5 mm²), solid or tin-bonded conductors
• 3 mm pin spacing
• Current rating up to 3 A and a rated voltage of at least 320 V(UL) or 160 V(IEC)
WAGO’s proven Push Wire connection also provides easy push-in termination of solid conductors. All WAGO SMD terminal blocks are available in tape-and-reel packaging for automated PCB assembly, making the 2059 ideal for the manufacture of small LED modules, designed for use in spotlights, downlights and streetlights.
WAGO
www.wago.us
The post Ultra-compact WAGO terminal block approved for larger conductors appeared first on Connector Tips.
Filed Under: Connector Tips, MOTION CONTROL, Terminal blocks
