Ultra-durable LED lights rated with up to 50,000 hours lifespan
By Leslie Langnau | June 22, 2018
Binder USA offers LED lights constructed with stainless steel for a durable shell that is IP69K rated when mated to a binder molded connector. A 120-degree angle of illumination is provided and 50,000 hours of reliable lighting ensures dependable results from the binder LED light bar. For simple and flexible installation, binder provides mounting brackets and power supplies. Power supplies can be hardwired with an inline power converter, or operators can use an optional 24V AC power converter overmolded to a binder M12 connector.
• 250, 358, and 412 mm lengths available
• Up to 569 lumens and 120° angle of light
• 20mm diameter tube design
• IP69K rated for protection from high-pressure and steam cleaning
• Up to 50,000 hours lifespan
• Neutral white 4,000 K
• Connection via M12 connector
• Low voltage luminaire
• UL listed file# E475844
• Used with class 2 power supply
Binder USA, LP
www.binder-connector.us
Filed Under: Flanges • supports • mounts • brackets, Lights • signal lamps • indicators
Tagged With: binderusa
TEXELCO : Series 180 multi color beacon with audio
Space-saving light grid provides maximum flexibility and function
SuccessStory-Flestic-WER
Maximizing your machine monitoring and data collection system
“Click-Clack” mounting system means quick installation without tools
Going small with 3D printing
