    • On the Floor
Ultra-miniature M3 Threaded Slide Sleeve Valve
By Design World Staff | February 15, 2007
Greenland, NH — Beswick announced the release of a new ultra miniature M3 threaded slide sleeve valve (part number M3SV-N). The new M3SV-N slide sleeve valve is another addition to Beswick growing M3 product line. It provides efficient control (on/off) of gas or liquid in an in-line configuration. The valve can be attached directly in a fluid circuit and does not require panel mounting.
The M3SV-N weighs only 4.6 grams and saves space. It is only about 20 mm (0.78”) long from end to end. The valve is a 2-way (non-venting) device.  There is no preferred flow direction. Inlet can be through either M3 internal threaded port. Maximum inlet pressure is 250 psig. Approximate flow orifice size is 0.6mm  to 0.7 mm (0.024” to 0.028”) diameter.
Valve materials can be brass or stainless steel. Buna-N is the standard O-ring material.  Optional O-ring materials are EPDM, Fluorocarbon (Viton®) and Silicone.
Beswick’s new M3 threaded slide sleeve valve features Beswick’s captured O-ring seal design for leak-tight sealing. It sets an industry standard for miniaturization and high performance. The M3SV-N is designed and manufactured for applications where space savings, leak-tightness, durability, and light weight are required.
Applications include: portable fuel cells, medical and dental equipment, instruments, laboratory equipment, semiconductor manufacturing equipment, aerospace equipment, packaging machinery, industrial robots and many more.
For more information, please contact:
Mike Donati
Beswick Engineering Co., Inc.
284 Ocean Road, Greenland, NH  03840-2442 USA
Phone:   +1 603.433.1188
Fax:       +1 603.433.3313
E-mail: [email protected]
Website: http://www.beswick.com
:: Design World ::
Filed Under: Aerospace + defense, Semiconductor manufacture, Valves, Medical-device manufacture, FLUID POWER, Packaging
  • Finally, hard data on humanoid robot cost in the factory
    • On the Floor
