Ultrachem Introduces Synthetic Compressor Lubricants
By Stacy Combest | May 22, 2013
Ultrachem has developed a new line of high-performance synthetic lubricants – the Chemlube Plus Series – designed to be used in a wide variety of rotary screw and rotary vane compressors. True universal lubricants, the Chemlube Plus Series is fully compatible with most OEM Rotary Screw compressor oils and can be used to top off and replace existing fluids.
The Chemlube Plus Series lubricants are made with a very thermally and oxidatively stable polyol ester (POE) blend.  These oils were designed to take advantage of superior lubricating properties inherent in polyol esters, and yet be economical, by combining them with less expensive synthetics.
These fully synthetic premium lubricants are formulated to form less varnish under high temperature applications and to be more resistant to acidic intake air than the polyalkylene glycol (PAG) coolants.  Under normal operating conditions users can expect to obtain up to 11,000 hours of lubricant service life in rotary screw compressors.  The line is available in ISO grades 32, 46 and 68.
Ultrachem-Chemlube-Plus-Series-Lubricants
Typical industrial applications for the Chemlube Plus Series include: rotary screw compressors, rotary vane compressors, centrifugal compressors, and vacuum pumps.  Chemlube Plus Series lubricants offer these performance benefits:
  • outstanding thermal and oxidative stability
  • extended drain intervals reduces oil disposal
  • wide operating temperature range
  • excellent anti-wear protection
  • compatibility with most compressor oils
  • improved safety – high flash point
Ultrachem
www.ultracheminc.com
Tagged With: ultrachem
