Minneapolis, MN — SICK launches the UM30-2 Ultrasonic Distance Measurement Sensors, featuring a new EasyTouch display and keypad that enables easier setup, configuration, and access to advanced problem solving features. The UM30-2 line offers increased measurement performance and is 25% shorter, providing more installation options. These sensors are ideal for detection and distance measurement applications, such as roll diameter control, level control, clear bottle detection, and collision avoidance.
The sensors’ increased performance includes actual measurement enhancements and valuable advanced features that can be activated to solve common application problems. The sensors’ resolution has been improved and now offers 0.18 mm resolution throughout the entire measurement range of the UM30-2 family. The new EasyTouch display and keypad allow for easy setup and quick commissioning and provide access to 14 advanced features without using any external PC or programming module.
Advanced features enable users to connect multiple sensors together to act as one large sensor, which increases the sensing area for more robust collision avoidance or for monitoring difficult target surfaces. They can also be connected together and programmed to multiplex to avoid cross talk and mutual interference. Another common problem solved by using the sensors’ advanced features is to ignore foreground or background targets, making it ideal for level detection to ignore signal reflections from the rim of the vial/bin/hopper/bottle/tube and only output the distance to the material inside. These solutions were previously not available in standard ultrasonic sensors and now provide more opportunities for you and your customer.
SICK
www.sickusa.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
