Understanding Ringfeder’s locking assemblies
By Mike Santora | August 11, 2021
Ringfeder-locking-assembliesRingfeder offers many types of Locking Assemblies. These friction-locked shaft-hub connections precisely fasten all types of hubs. They can also bridge relatively large fit clearances and are easy to install, adjust and remove.
When browsing the Ringfeder product page, one might notice that some of the standard Locking Assemblies come in different models. Here, Ringfeder breaks down the differences between these models, enabling you to select the right Locking Assembly for your application.
Standard Model Differences: 7013
On Ringfeder’s 7013.0 model, the flange of the inner ring has a slightly smaller diameter compared to the outer diameter of the Locking Assembly — a design that is completely inserted in the mating hub. When tightening the screws of the Locking Assembly during installation, the hub will move axially toward the screw heads. The .0 design is the more popular type, as the small amount of axial movement is usually fine. Because it’s completely inserted in the hub, this design also creates a more compact design since the screws and flange don’t stick out from the hub.
On the 7013.1 model, the flange of the inner ring has a diameter that’s larger than the outer diameter of the Locking Assembly, and the flange butts up against the face of the mating hub. When tightening the screws of the Locking Assembly during installation, there is no axial movement when positioning is critical.
Standard Model Differences: 7015
Ringfeder’s 7015.0 Locking Assembly enables the maximum amount of torque for the design. The 7015.1 model has lower torque and applies less contact pressure to the mating shaft and hub so as not to yield or break the mating hub. As a result of these features, this design is ideal for applications where the hub is thinner or the hub material isn’t very strong.
Standard Model Differences: 7012
Ringfeder’s standard 7012 is its most popular model for most applications. On the 7012.2 model, the company optimized the stress profile of the rings to withstand the high demands of bending moment applications. Compared to the base 7012 model of the same size, this version has fewer screws, reducing the stresses in the Locking Assembly. In addition, Ringfeder uses screws with a special, corrosion-resistant material that makes them stronger than commercial-grade screws. Without this special design, the locking device can easily become damaged during the bending cycles over time.
Learn More About Ringfeder Locking Assemblies
No matter the model, these Locking Assemblies join shaft components by making 360° contact with the shaft and its mating component. These components are characterized by their backlash-free nature, even distribution of forces, and elimination of failure-prone keyways. Our standard shaft diameters range from 6 to 1,000 millimeters (metric) and from 3/4 to 8-in. (imperial). Ringfeder also offers inch sizes for our 7515, 7013.0, 7013.1, 7012, 7006, 7005, and 7003 models.
Ringfeder
Filed Under: Coupling Tips
Tagged With: Ringfeder
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
Torque transducers and test machinery use CD couplings from Zero-Max
