Unidrive DFS free-standing drives now available from Control Techniques
By Lisa Eitel | August 2, 2019
Users of high-power drives can now receive pre-engineered ready-made drive enclosure systems in as little as one day for emergency breakdowns — via Control Techniques’ Drive Free Standing (DFS) Series.
Mission-critical machines and project timelines are supported with rapid deployment capabilities of select factory stocked units, as well as industry best leadtimes across the power range. Designed for optimal reliability, serviceability, and application flexibility, Control Techniques’ Unidrive DFS series enclosures range from 100 to 1,250 hp and can control standard ac induction motors, high-efficiency permanent magnet motors, and high dynamic servomotors.
The pre-engineered packaged-drives come ready-to-use with no additional engineering needed and are designed to accommodate customer-specific components as well as a suite of standard factory options to support demands across industrial applications.
Drive Free Standing is simple to configure using the optional door-mounted HMI or no-charge Windows-based Connect PC tool with Easy Setup Wizard.
NEMA12 is standard, with a UL Type 1 enclosure also available. Boosting reliability, Drive Free Standing also uses standard production drive modules from Control Techniques’ globally installed base, manufactured to highly consistent procedures with multiple test gates and full traceability.
Durability is reinforced on drive modules via standard conformal coated PCBs, a patented air flow system which minimizes ingress issues and maximizes cooling, plus a wide supply voltage tolerance. Serviceability of the enclosure and drive has been incorporated in the design for mission critical applications. An internal chassis rail-system allows for easy and& secure front accessibility of drive and key components, reducing downtime associated with suboptimal equipment access and handling.
Drive Free Standing is based on Control Techniques’ globally installed Unidrive M600 and M700 drive modules. Unidrive M700 provides high-performance motor control up to 3,000 Hz current loop bandwidth and up to 250 Hz speed loop bandwidth.
Unidrive M700 includes; onboard motion and machine control with open programming. Unidrive M700 has onboard Ethernet, including EtherNet/IP, PROFINET, Modbus TCP/IP and RTMoE (Real Time Motion over Ethernet).
Both drive models also include integration options to further expand communications across all major industrial protocols, plus options covering additional control, I/O and encoders.
For more information visit www.ControlTechniques.us.
Tagged With: controltechniques, nidec
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Schneider Electric launches Universal Automation Discovery Packs to foster industrial innovation
Encoders from SIKO support Industrial Ethernet
Draw-wire encoders from SIKO measure position, speed and inclination
Incremental encoders configurable via NFC (near-field communication)
