Tri-Tronics has introduced the first “True Color Sensor” designed to perform as well as an instrument or a spectrometer. The new Smarteye Colorwise sensor will solve the most difficult color applications at higher speeds than expensive color cameras or other sensors. It is the ideal low cost solution for intricate color sorting or inspection problems in high speed printing, packaging and converting lines.
Features and benefits:
- Low Cost Solution vs. cameras, other sensors or spectrometers
- Solves the most difficult shade-to-shade or color-to-color applications
- Selectable outputs, timers, resolution, speed, etc. to fit all applications
- 4-Channel Monitor for at-a-glance performance feedback
- 4 Digital Outputs and 3 Analog Outputs
- Capture Colors from HMI, PLC or Remote Buttons
- Selectable Speed vs. Resolution
- Selectable Color vs. Color + Intensity
Tri-tronics
www.ttco.com
Filed Under: Sensor Tips
