    • Subscribe!
Universal code reader for all common 1‑D and 2-D codes
By Andrew Zistler | March 16, 2016
pepThe MAC335 Universal Code Reader from Pepperl+Fuchs is compact, economical, and easy-to-mount and configure. The stationary barcode imager reads the most common 1-D and 2-D code symbologies without having to change settings. Its extremely high 1.3 megapixel resolution enables it to accurately and reliably read small and large codes at distances ranging from 20 mm to 300 mm at 3 readings per second.
The MAC335 universal code reader also features Pepperl+Fuchs’ standard operator interface, Vision-Configurator. Vision Configurator allows you to set parameters intuitively and displays images from the reader. Using Data Matrix control codes to parameterize the MAC335 eliminates the need for separate operating software. As a result, configuration, startup, and testing processes are simple and fast.
These 24 VDC devices offer IP65 protection, and are rated for use in temperatures ranging from 0 °C … 50 °C (32 °F … 122 °F).
The MAC335 are well suited for use in any number of industries, including packaging, print and paper, automobile, material handling, and pharma.
Pepperl+Fuchs is a world leader in the design, manufacture, and application of high quality factory and process automation products and services. Pepperl+Fuchs pioneered the development of proximity sensors 50 years ago, and has set the standard for innovation and quality ever since.
Pepperl+Fuchs
pepperl-fuchs.us
Filed Under: Factory automation, Software
Tagged With: Pepperl+Fuchs
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
