Universal Pulley Torque Sensor
By Patrick Curran | August 19, 2009
Sensor Developments Inc’s universal pulley torque sensor addresses the needs to measure belt or chain torque on pulley systems.
Capable of accepting various pulley wheels and shaft diameters, this sensor features a highly accurate integrated sensing element, capable of resolving low torque levels while being exposed to high radial loads created by belt drive systems. Use it to replace a standard pulley system for equipment like engines, generators, fluid pumps, or other motor driven equipment and continuously monitor real time torque while in operation.
This sensor can be adapted to a wide range of belt drive systems and can be installed in a dynamometer test stand or on vehicle. Various torque capacities and pulley gears can be designed to meet your specific requirements.
www.sendev.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
Comments
  1. Siddeshgowda says
    May 20, 2019 at 9:33 am
    Need to measure a pulley shaft torque in agriculture tractor , looking for sensor
    [email protected]
mti
MTI
moog
