Universal Voltage Sensors
By Design World Staff | September 15, 2008
Minneapolis, MN‚—Banner Engineering Corp. introduces the WORLD-BEAM‚® QS18 Universal Voltage sensors featuring ac or dc voltage operation. The 3-wire photoelectric sensors deliver solid-state output for reliable presence/absence detection in a wide variety of applications, including package and material handling. In addition, the rugged sensors feature the compact, self-contained WORLD-BEAM housing with a variety of mounting options to meet versatile requirements and easily fit or retrofit most configurations.
QS18 Universal Voltage sensors provide 20 to 140V ac or dc, or 20 to 270V ac or dc operation with a choice of P-MOSFET (sourcing) or N-MOSFET (sinking) solid-state output for enhanced sensor life and faster switching and response time than mechanical relays. The versatile sensors are light operate or dark operate, depending on the model, and long-range diffuse models are available for sensing up to 1 m. Additionally, QS18 Universal Voltage sensors feature robust housing with 18 mm threaded barrel or basemount, side-mount and retrofit bracket options‚—all in a rugged IP67 (NEMA 6) housing and with encapsulated electronics to resist harsh environments. Plus, bright LED status indicators are visible from 360 degrees for simple status monitoring from any angle.
Rugged QS18 Universal Voltage sensors are rated PW12 (1200 psi) for washdown environments and are UL listed, CSA certified and CE marked. Plus, models offer a 300V rated 2 or 9 m attached cable or 4-pin Micro-style pigtail quick-disconnect, and a 600V cable is also available.
www.bannerengineering.com
Filed Under: SENSORS, TEST & MEASUREMENT
