    • On the Floor
Unlimited O-Rings
By Design World Staff | July 5, 2007
Apple Rubber Products, Inc., stocks standard AS-568B sizes and most common metric size O-rings plus a wide variety of non-standard, mil spec, and government standard O-rings. Apple Rubber can deliver the exact sealing solution for almost any application.
Apple Rubber can ship most products immediately, saving time and money. Apple Rubber stocks a large inventory (standards, metrics and unusual sizes) of O-rings including every standard AS-568B size, with I. D.'s from 1/32″ (. 794 mm) to 26″ (66.04 cm), O.D.' s from 3/32″ (2.38 mm) to 26-1/2″ (67.31 cm) and cross sections (widths) from 1/32″ (. 794 mm) to 1/4″ (6.35 mm).
From standard to hard-to-find, Apple Rubber even has the materials for most applications, including Viton®, Fluorosilicone, Polyurethane and Teflon®. Most often, the customer requests for size and compound are in Apple Rubber’s stock of over 300,000,000 O-rings. O-ring inventory is constantly restocked to assure immediate delivery of any size in large or small quantities.
Apple Rubber also offers ExpresSeal® as the fastest way to get the seal you need. Seals can be produced and quickly shipped in virtually any standard profile according to specifications from. 250″ I. D. (6.35mm) up to 21″ O. D. (533 mm). ExpresSeal can handle all prototype or emergency seal requirements, either machined, off-the-shelf, or custom molded for emergency repair. ExpresSeal is set up to respond quickly to even the most challenging sealing requirements.
Web: www.applerubber.com
:: Design World ::
Filed Under: Seals • gaskets • O rings
    • On the Floor
