In each of these industrial unmanaged 8 port gigabit switches, the RJ-45 ports support 10/100/1000Mbps speeds with auto-negotiation and auto-MDI-/MDX detection. Housed in compact enclosures of 50 mm, these devices reduce the footprint of the control cabinet. They each have an operating voltage of DC 9 to 57 V and two LEDs per port for flexible and easy-to-use operations.
The 852-1112 economical style industrial switch is DIN rail mounted and is powered with 24 Vdc.The 852-1102 industrial switch offers dual power feeds for redundant power capabilities as well as operations over a wide voltage range and a monitoring alarm relay.
WAGO
www.wago.us
Filed Under: CONNECTIVITY • fieldbuses • networks
