    • Subscribe!
Unthreaded KEYHOLE® and SNAP-TOP® Standoff Fasteners
By Editor | July 25, 2012
PEM® unthreaded KEYHOLE® and SNAP-TOP® standoff fasteners provide ideal solutions to mount and detach PC boards, panels, or components easily without requiring any tools or additional hardware. Both families of fasteners are uniquely designed to provide secure and reliable attachment, reduce or eliminate risks associated with loose hardware potentially damaging internal circuitry, and ultimately enable “screwless” designs of subassemblies.
PEM KEYHOLE (Type SKC™) stainless steel self-clinching standoffs allow for a PC board or panel to be slipped quickly into place and then removed from an assembly by simply sliding the board sideways and lifting it off. Further security can be achieved when used along with a single threaded standoff.
PEM-Standoff-Fasteners
PEM SNAP-TOP (Types SSA™, SSS™, and SSC™) aluminum, steel, and stainless steel standoffs clinch into metal sheets and Type KSSB™ brass standoffs broach into PC boards. They employ a spring action to hold boards and panels securely, while allowing for their quick attachment and removal using a simple snap-on/snap-off operation.
All install permanently in sheets or panels as thin as .040” / 1mm by squeezing them into a properly sized hole using using a PEMSERTER® or any standard press. Upon installation, the fasteners become integral parts of the assembly.
Detailed specifications for KEYHOLE standoffs (Bulletin SK) and SNAP-TOP standoffs (Bulletin SSA) and free part drawings (PEM CAD Library) for these RoHS-compliant fasteners can be accessed at www.pemnet.com
PennEngineering
www.pemnet.com
Filed Under: Fastening + joining • locks • latches • pins
Tagged With: PennEngineering
Southco introduces stylish corrosion-resistant stainless steel positioning hinge
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
    • Subscribe!
