    • Subscribe!
Urethane Covered Bearings for Smooth, Quiet and Non-Marring Operation
By Frank Tobe | July 17, 2014
Fixtureworks® (Fraser, MI), a supplier of workholding components, material handling products, machine tool components and fixturing accessories now offers Fairlane® Products Urethane Covered Bearings.
Available in stock, ready to ship with no lead time, no minimum order and no tooling required, they are available in both inch and metric sizes. This is counter to traditional availability of these types bearing rollers, many of which require lead time, minimum orders and tooling. They have a smooth urethane surface that is cast directly on a precision sealed ball bearing. Not only are they smooth and provide for quiet and non-marring operation, they also provide excellent abrasion resistance and durability.
FixtureWorks
Fixtureworks now offers Fairlane® Products urethane covered bearings in both inch and metric sizes for smooth, quiet and non-marring operation.
The inch and metric sizes are offered in two styles, single bearing and double bearing. The single bearing style is available in diameter sizes from 0.750 to 3 in. and from 20 to 70 mm. Widths range from 0.196 to 0.563 in and 5 to 12 mm.
The double bearing style is available in diameters from 0.750 to 3.00 in. and 20 to 70 mm, with widths from 0.392 to 1.125 in and 10 to 24 mm. Durometers are available from 35 to 95 in both inch and metric sizes.
The urethane covered bearings are also available with stud mount. These covered bearings also have a smooth urethane surface. They come assembled with a button head cap screw, spacer and locknut for easy mounting. The stud mounts, also available in metric sizes, are available in diameters from 0.875 to 2.00 and 20 to 50 mm with stud sizes ranging from 1⁄4 to 5/8 in. and M5 to M12, durometers from 35 to 95.
Besides the Fairlane® Products urethane covered bearings, Fixtureworks offers Fairlane® Products full line of grippers, rest pads, Swivots® swivel/pivoting positioning components, Quick Release ball-lock pins, rollers and bumpers; Kipp® rest and riser pads, levers, handles, knobs, and hand wheels; Imao® O.D. Clamps, manual clamps, supports and stops, risers, T-nuts, sliding mounts, springs, supports, grid plates and blocks; OK-Vise® single and double wedge clamp designs; Mitee-Bite® low-profile edge clamps.
FixtureWorks
www.fixtureworks.net
Filed Under: TECHNOLOGIES + PRODUCTS, Bearings
Tagged With: fixtureworks
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
Ethernet remote I/O modules add Conditional Logic Computing
Self-contained actuator for a variety of applications
    • Subscribe!
