LAGUNA HILLS, CA — USAutomation introduces the Accuriss™ Series of fully integrated and packaged intelligent step motors. Accuriss motors combine a 1.8° hybrid step motor with a microstep drive and an intelligent controller in one easy-to-mount package.
Measuring only 1.1 inches across, the Accuriss 28 is capable of microstepping at up to 1,600 steps per revolution which virtually eliminates the resonance inherent in step motors. The Accuriss 60 is 2.36 inches across and can microstep up to 51,200 steps per revolution. A high level command language is embedded in the controller to allow users to execute real-time motion commands or write programs which can be executed with a start command, upon power-up, or via input signals.
Both Accuriss motors include programmable I/O ports. Communication to the motors is via RS485 and up to 16 units can be daisy-chained together. A USB-to-RS485 converter is a standard Accuriss option to allow users to communicate with standard USB ports.
Three different lengths of each motor are available allowing the Accuriss 28 to achieve up to 11 oz in of dynamic torque and the Accuriss 60 to achieve more than 300 oz in. The Accuriss 28 can be supplied as a standard motor option on USAutomation’s Microstage™ positioning system.
Accuriss motors can be programmed from any standard terminal program (such as HyperTerminal) or from the Accuriss Terminal™ program, a free dedicated terminal program available for Windows. Once the Accuriss is programmed it is capable of independent motion sequences with only the DC power source connected.
USAutomation
www.usautomation.com
Filed Under: Automation components, Motion control • motor controls, Motors • stepper
