Saelig Company, Inc. has introduced PS4224-IEPE – a new 20MHz 12-bit 2-channel PC oscilloscope adapter with an integrated IEPE (Integrated Electronic Piezo Electric – IEEE 1451.4) interface, making it compatible with any industrial standard IEPE accelerometer or microphone. Intended for use with industry-standard accelerometers for monitoring vibrations and acoustic waveforms in the field, PS4224-IEPE is suitable for mechanical analysis without add-on modules. In addition, there are several other sensor types which use this interface, such as microphones, impulse hammers, acoustic, force and pressure sensors. Designed for customers who require measurements from high-sensitivity accelerometers, PS4224-IEPE’s 12-bit resolution can capture even the smallest incremental changes. The IEPE sensors are powered via the integrated constant current sources on the BNC input connector, but it can also be used as a standard PC-hosted 2-channel digital storage oscilloscope for other non-IEPE applications without modification. With a fast 80 MSa/s real-time sampling rate and input ranges from ±50 mV to ±100V full-scale, the PS4224-IEPE can handle small signals from sensors as well as higher voltages from power supply circuits and motor drives. PicoScope software for Windows PCs is included
585-425-3753, www.saelig.com
