Anoka, MN‚â€â€Hoffman introduces Utility Junction (UJ) Sectionalizing Enclosures, designed to provide above ground housing for sectionalizing, tapping or terminating underground distribution systems while resisting challenging outdoor conditions. UJ enclosures are offered in single- and three-phase models. Each of the 15 UJ enclosure models is available in large or small orders with short lead times, providing the convenience of in-stock solutions with the flexibility to meet diverse application needs.
With resilient steel or aluminum construction and a tamper-resistant design, UJ enclosures withstand the toughest environmental abuse to deliver extended operational life and minimize replacement costs. Each UJ enclosure features a self-engaging wind stop that holds the cover in the open position for easy access to terminations. A recessed pentahead latch and interlocked padlock provision ensure the enclosure closes securely. Several available sizes, plus standard 12 gauge steel or .125 aluminum construction or optional stainless steel, combine with Hoffman‚’s extensive modification services to provide a multitude of configuration possibilities.
UJ enclosures deliver a comprehensive utility industry solution by combining durable construction with flexible design options, offering simple above ground access to underground distribution system terminations.
Filed Under: Cabinets • enclosures • control panels, Electronics • electrical
