UV Curable Compound With Superior Gap Filling Properties
By Patrick Curran | October 29, 2009
HACKENSACK, NJ – Master Bond UV10TK40 is a UV curable, no-mix epoxy resin system with exceptional sealing and gap-filling properties. It excels in applications such as aligning parts and bonding irregularly shaped surfaces, especially in production environments where increased speed and reduced waste are paramount. Its very high surface hardness (Shore A >75) also makes it an excellent choice for clear coating.
UV10TK40 is easy to apply and has a viscosity of 35,000 – 45,000 cps. In addition to our standard packaging, UV10TK40 is also available in convenient, ready-to-use syringe applicators. The system contains no solvents or other volatiles and is 100% reactive.
UV10TK40 is not oxygen inhibited and cures rapidly in the presence of air upon exposure to UV light at room temperatures. It forms highly durable bonds with a typical tensile strength of 8,300 psi, a Young’s modulus of 245,000 psi, and an elongation at break of 6%. Additionally, it has good dimensional stability and high heat stability (94°C Tg).
MASTER BOND INC.
www.masterbond.com
Filed Under: Adhesives • epoxies, Materials • advanced
EXE014 - Image 1
