Validate Fieldbus Segments
By Design World Staff | May 18, 2010
Segment Checker version 1.20 helps you validate the design of all Foundation fieldbus and Profibus PA segments, even in hazardous areas. You drag and drop components into the project window, and edit the attributes to build a fieldbus segment.
Pepperl-Fuchs-Segment-Checker-v-1.20
New to version 1.20 are the latest FieldConnex fieldbus products and enhanced calculations for fieldbarriers used in the High Power Trunk method. Additionally, the software lets you export a project in a graphic format for use in different media. It also lets you display, archive and print a design, and import field devices from a library, or create new devices with the “device editor” feature.
Pepperl+Fuchs
www.pepperl-fuchs.us
Filed Under: Networks • connectivity • fieldbuses
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
