    • Subscribe!
Valves for Electro-hydraulic Axis Controls
By Design World Staff | May 5, 2011
The KBS series valves support centralized and distributed axis control architectures. They feature programmable onboard electronics and integral spool Linear Voltage Differential Transformer (LVDT) sensors for precise, accurate, responsive axis control capabilities. The initial products are offered in ISO-3 and ISO-5 sizes with rated flows of 40 LPM and 100 LPM (10.6 and 26.4 gpm), and maximum flows of 75 lpm and 180 lpm (19.8 and 47.6 gpm) respectively. Dynamic bandwidth for the ISO-3 valves is 150 Hz and 100 Hz for the larger ISO-5 models. Both have 350 Bar (5,075 psi) rated A- and B-ports and 250 Bar (3,625 psi) rated T-ports.
Eaton KBS Series Valves
Eaton Corporation
www.eaton.com/hydraulics
Filed Under: Fluid power, Hydraulic equipment + components, Valves
Examining direct drive hydraulic maintenance
cylinder
Small, compact cylinder boasts large preload capacity
High modulus plastics for off-highway
Peninsular-Cylinder-top-10-coolest-things
Custom Peninsular Cylinder design named a finalist for “Coolest Thing Made in Michigan”
    • Subscribe!
