    • On the Floor
Valves With Integrated AS-I Connection
By Design World Staff | April 20, 2007
Series CA44 valves are two station manifolds for AS-I serial link (bus) applications, complying with AS-I specification V2.11 Rev. 1. Manifold choices include: with or without digital inputs and with or without auxiliary power. The valve stations can be 4-way, 2 position valves, dual 3-way, 2 position valves, or a blanking plate. The plug-in valve eliminates disturbances to electrical wiring because it simultaneously makes both the electrical and pneumatic connections. Flow is 0.2 Cv (200 l/min), with pressure from 29 to 116 psi. Voltage is 24 Vdc, with a protection rating of IP67 (NEMA 6). Up to four valve functions and four electric inputs are possible with one AS-I address.
Bosch Rexroth Corporation
www.boschrexroth-us.com
Filed Under: Valves
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
