VARAN Compatible Transducer
By Design World Staff | March 14, 2011
Micropulse AT Linear Position Transducer with the VARAN Bus interface tracks the location of up to four position-marker magnets. This transducer outputs a start/stop signal, which is used to calculate the position of each magnet using the transducer length and resolution. It is available in a non-contact, floating magnet configuration, with optional measuring ranges from 50 mm up to 1.5 m. The VARAN client chip is embedded into the transducer itself as a low-cost FPGA, allowing simple read/write configuration and making it an economical solution for linear positioning. VARAN Bus is an Ethernet-based industrial network protocol based on IEEE 802.3 100TX Standard Ethernet technology.
VARAN compatible transducer
Balluff Inc.
www.balluff.com/AT
Filed Under: Linear motion • slides, Sensors (position + other), Sensors (proximity), Test + measurement • test equipment
mti
MTI
moog
