VariBlast Precision Safety Air Gun is the People’s Choice
By Heather Hall | December 16, 2022
EXAIR’s VariBlast Precision Safety Air Gun has won the 2022 People’s Choice award from Professional Tool and Equipment News (PTEN). These safety air guns provide a focused blast of air capable of handling tough jobs with remarkable strength while minimizing air consumption and noise. This OSHA-safe air gun employs an engineered, full-finger, variable flow trigger able to produce varying force upon a target simply by pulling the trigger. The VariBlast is available with a standard, 12-in. or 20-in. extension which can also be outfitted with type 316 stainless steel or PEEK thermoplastic air nozzles for non-marring applications.
The 1/4 NPT VariBlast Precision Safety Air Gun has a convenient hanger loop built into it. The air gun body is made of high-impact acetal thermoplastic. The airflow that exits the nozzle can’t be blocked, assuring safe operation and meeting required OSHA standards 1910.242(b). A quiet 75 dBA noise level is well below the limits of the OSHA noise exposure standard 29 CFR 1910.95(a).
A variety of other Super Air Nozzles with different force and flow values are available. All EXAIR’s Safety Air Gun product lines are CE-compliant and use engineered air nozzles for high performance and safety. All are available with extension pipes and Chip Shields.
EXAIR
www.exair.com
Filed Under: Awards • acquisitions
Tagged With: exair, EXAIR Corporation
