Pepperl+Fuchs introduces VAZ-LAMP Series Stack Lights. Designed to complement the company’s extensive line of industrial-grade stack light LEDs, audible alarms and related accessories, VAZ-LAMP series stack lights provide low-cost visual “warning” or “ready” status indication in applications where LED-lit stack lights are too costly to warrant use.
These stack lights are available in blue, green, clear, yellow and red. They are lit by an incandescent light bulb, so should a bulb burn out it can quickly and easily be replaced for a few dollars, rather than having to replace the entire stack light. They have a per unit list price of $23, and replacement bulbs are just $5 each. VAZ-LAMP series stack lights are compatible up to four lights high with Pepperl+Fuchs’ As-Interface light tower module, or can be used as a stand-alone solution stacked up to five lights high.
Pepperl+Fuchs
www.pepperl-fuchs.com
Filed Under: Factory automation, Lights • signal lamps • indicators, Safety systems + components
