VCO Operates at 1690 MHz With a Control Voltage Range of 0.3V~4.7V
By atesmeh | January 12, 2015
Crystek’s CVCO55CC-1690-1690 VCO (Voltage Controlled Oscillator) operates at 1690 MHz with a control voltage range of 0.3V~4.7V. This VCO features a typical phase noise of -120 dBc/Hz @ 10 KHz offset and has excellent linearity. Output power is typically +2.5 dBm.
Engineered and manufactured in the USA, the model CVCO55CC-1690-1690 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 5V, with a max. current consumption of 25 mA. Pulling and Pushing are minimized to 1.0 MHz and 0.5 MHz/V, respectively. Second harmonic suppression is -15 dBc typical.
The CVCO55CC-1690-1690 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
