    • On the Floor
VCO operates from 2558 MHz to 2575 MHz
By atesmeh | April 10, 2012
Crystek’s CVCO55CC-2558-2575 VCO (Voltage Controlled Oscillator) operates from 2558 MHz to 2575 MHz with a control voltage range of 0.3 V to 4.7 V. This VCO features a typical phase noise of -120 dBc/Hz at 10 kHz offset and has desirable linearity. Output power is typically +8 dBm. The model CVCO55CC-2558-2575 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 8 V, with a max. current consumption of 29 mA. Pulling and Pushing are minimized to 2.0 MHz and 0.2 MHz/V, respectively. Second harmonic suppression is -15 dBc typical. The VCO is appropriate for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Crystek Corporation
800-237-3061, www.crystek.com
  • Agentic Requirements Engineering: Reduce Friction in Requirements Workflows
  • Five trends in automation for the second half of 2026
    • On the Floor
