Versaflex™ Meltblown Polypropylene Filter Cartridges
By Design World Staff | May 4, 2009
Sheboygan, WI‚—Pentair Industrial introduces the Versaflex‚â„¢ Series meltblown polypropylene filter cartridges, delivering high flow rates and process compatibility for applications including food and beverage, oil, finish machining, solvents and others. The cartridges are constructed using a glue-free design and a thermal bonding process that seals the endcap securely to the cartridge, assuring bypass-free operation. Available in two models, VF-250MB and VF-250HE, Versaflex Series cartridges offer a variety of diameters, lengths and micron ratings, as well as chemical compatibility in most applications.
Versaflex Series cartridges are built with 100% polypropylene and manufactured with only FDA-listed materials, with no surfactants, binders or adhesives used in production. Designed with graded density matrixes to effectively trap contaminants, Versaflex cartridges deliver high dirt-loading capability, as well as long operational life. Both Versaflex models offer superior filtration, and the VF-250HE offers high efficiency, operating at 99% efficiency with micron ratings from one to 75. Plus, the micron rating is stamped onto each cartridge for simple identification.
To withstand a wide array of application environments, Versaflex cartridges operate at a temperature rating of 40‚° to 180‚° F. In addition, to ensure high quality and reliable operation, cartridges undergo rigorous performance testing. With these robust temperature ratings and proven performance, paired with high efficiency and a bypass-free design, Versaflex Series cartridges provide better flow rates and longer life than standard spun-bonded and stringwound cartridges.
Pentair Industrial
www.pentairindustrial.com
Filed Under: Filters (mechanical) for air + fans, Fluid power
Next steps in fluid power connections
cylinder
Small, compact cylinder boasts large preload capacity
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
Fluid power manufacturer receives environmental stewardship recognition
