Versatile Scanner Ensures Safety in Robotic Cells
By Editor Design World | August 13, 2014
The number of opportunities in industrial applications that risk a person’s safety are numerous and varied. One solution to improve safety is the OS32C-4M safety laser scanner, which offers the versatility needed to solve diverse presence detection and collision avoidance application needs. The OS32C-4M safety laser scanner is a Type 3 laser scanner with a 4-m safety range, 15-m warning zones and a 270° detection angle for safeguarding large robotic cells and body entry detection. The scanners can also be mounted 4-m high to eliminate the possibility of tampering.
A pollution tolerance mode ensures safe machine operation, even in the dirtiest and dustiest application environments. The result is more flexible safety monitoring and configuration for improved machine safety and productivity. All models meet global standards for worldwide application; select models are available for same-, 3- or 5-day shipment.
omron-os32c-4m-safety-laser-scanner
These safety laser scanners can report status and measurement data over EtherNet/IP. This helps keep machines up and running by enabling users to check the operating state and analyze the cause of an emergency stop using a LAN, and take quick corrective action, even in large-scale applications with multiple scanners. They are also available with user tools that help speed customer development time and conserve engineering resources.
Easy to use function blocks handle simple PLC controlled status and data updates. A simple and effective method of integrating the status and measurement data to a PLC, these function blocks can be used in the PLC code to automatically configure the PLC to process and display the information. Software examples are available for large process PC-controlled applications where large amounts of data are logged to determine product quality, consistency or process variations.
Additionally, the configuration tool provides a “maintenance access level” enabling users to make only non-safety related programming changes, and employs a “non-safety checksum” for easier re-commissioning when non-safety changes are made. A “zone coordinate import/export” function allows users to modify the shape and size of a monitoring zone by importing coordinates from a text file.
omron-os32c-4m-safety-laser-scanner-safety-zone
All OS32C safety laser scanners provide configurable object resolutions of 30, 40, 50 and 70 mm to accommodate hand and arm detection applications. They feature a compact 104.5-mm profile, light 1.3-kg weight and consume 5 W power (3.75 W in standby mode). Other features include up to 70 sets of flexible and easily configurable detection zones. The scanner is easy to handle and install. The status display and eight patented Individual Sector Indicators let you see at a glance the unit’s operating state and error codes, and assess the direction of an intrusion.
Omron Automation and Safety
www.omron247.com
Filed Under: Design World articles, The Robot Report, PLCs + PACs, Safety systems + components
Tagged With: omron
Hirschtick on the cloud, CAD, and the future
china-manufacturing-future-image
Is China’s manufacturing future in trouble?
