    • Subscribe!
Vibration, motion control, and processing tech highlight of ITT’s Pack Expo exhibits
By Mary Gannon | October 15, 2018
ITT Inc. and its Bornemann, Compact Automation and Enidine brands are showcasing a wide portfolio of packaging industry solutions at the 2018 PACK EXPO International, this week through Wednesday, in Chicago.
ITT Compact Automation's Composite Cylinder
ITT Compact Automation’s Composite Cylinder
ITT’s highly engineered energy absorption, vibration isolation, motion control and processing solutions are designed to provide reliability and extended service life for the most demanding packaging and automation applications. The company will highlight new and expanded technologies in hygienic pumps, drum unloading systems, motion control products for conveyor and robotic systems, and shock absorption and vibration isolation products that help to improve equipment uptime, throughput and safety in manufacturing environments. These latest innovations include:
  • Compact Automation Composite Cylinders: A new design innovation combines Compact’s small cylinder size in a powerful, lightweight, corrosion-resistant material. The Composite Cylinder Series is a linear actuator with a durable hollow rod option enabling use in vacuum pick-up applications in end-of-arm tooling. Designed in an equivalent size to Compact’s standard inch and metric series, the Composite Cylinders are 25-30 percent lighter than standard cylinders. This solution makes it possible for operators to either downsize a robotic application or simply handle heavier loads. The cylinder’s design also features a corrosion-resistant plastic, FDA-approved food-grade material ideal for challenging environments.
  • Enidine ECO Series Shock Absorber: The packaging industry’s first shock absorber with an environmentally friendly ROHS compliant design that stands up to the harsh environments faced by today’s most critical packaging applications. Both adjustable and non-adjustable models have the flexibility to accommodate a wide range of operating conditions and cover a variety of application input parameters.
  • ITT Enidine ECO Series shock absorberBornemann BINEM: Previewing exclusively at PACK EXPO and coming in 2019, the Bornemann BINEM is capable of emptying bins, drums and containers with less than 1 percent product waste. This advanced design is an ideal solution to empty products that are not self-leveling or cannot be handled by a drum pump or suction wand. BINEM is perfect for applications such as tomato paste, chocolate spread, cookie filling, peanut butter and meat paste.
ITT representatives will be available throughout Pack Expo International at booths E9443 (Bornemann), and N6333 (Enidine and Compact Automation). For more information, please visit each brand website at Bornemann, Compact Automation, and Enidine.
ITT
www.itt.com
You may also like:
  • ITT Enidine;s Adjustable Mid Bore Shock Absorber and wire rope isolator
    Industrial automation and motion control the focus of ITT Enidine’s…
  • ITT Compact Automation expands motion offerings to include electric actuators
  • FAQ: Where and why are miniature hydraulic shock absorbers useful?
  • Shock and vibration mitigation by design, not by mistake
  • ECO Series Line of Hydraulic Shock Absorbers from ITT
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, TECHNOLOGIES + PRODUCTS, ALL INDUSTRIES, Packaging, Linear motion • slides, Motion control • motor controls, Pneumatic equipment + components, Shocks + vibration control • gas springs
Tagged With: itt, ittenidine, compactautomation, ittcompactautomation
Dual high-temperature Cabinet Cooler systems for large enclosures
china-manufacturing-future-image
Is China’s manufacturing future in trouble?
    • Subscribe!
