VNTC (Vinyl Nylon Tray Cable) 600-V Type TC-ER control cables from AutomationDirect are suited for use in wet and dry areas, conduits, ducts, troughs, trays, direct burial and where superior electrical properties are desired. VNTC cable is available in 18 to 10 AWG with 3 to 24 unshielded copper conductors. Cables are cut to length in 1-ft increments with a 20-ft minimum.
Cable is rated for use in Class I, II, and III, Division 2 hazardous locations per NEC Article 501 and 502 and listed for exposed runs (TC-ER) per NEC 336.10. VNTC cable, with nylon layer insulation and THHN Polyvinyl Chloride jacket, is silicone free and can operate continuously at temperatures up to 75° C in wet locations and 90° C in dry locations.
Made in the USA, VNTC tray cable starts at $0.21 / ft. (20 ft. min.) and has a 1-year warranty.
AutomationDirect
www.automationdirect.com/vntc-cable
