New Hyde Park NY – All Metric Small Parts (aMsp) announce the availability of the …MLAT08MTH130B Series of viscous dampened hinges. These compact light weight, silent dampened hinges are designed to have higher torque, by using a newly developed rotary mechanism. Since damping force to the rotational movement of these hinges are applied by viscous resistance of the oil, the rotation becomes slow and soft. Typical applications include appliances, medical instruments telecommunication devices, storage cases, aircraft, audio-visual devices, etc. Outside dimensions measure 80 mm by 63 mm. 3-D CAD models are available for download at the aMsp Web site. The aMsp online eStore allows you to choose from a great selection of all types of hinges in steel, stainless steel, brass, nickel plated, galvinized steel, nylon, zinc plated, and many more.
aMsp offers an extensive selection of all Metric standard industrial machine components. Their products include: Hinges, {Flat Type, 4-Knuckle Type, 180O Type, Lift-Off Type, Concealed TypeAngled Type, Pipe Type, Friction Type, Double Pivot Type, Free Stopping TypeLifting Lid Type} Latches, Handles, Handwheels, Cranks, Grips, Levers, Locks, Catches, Screws, Washers, Springs, Keys, Plungers, Pins, Leveling & Support Feet. All of these products are 100% RoHS Compliant.
www.allmetricsmallparts.com/press/dampinghinges.htm
Filed Under: Fastening + joining, ASSEMBLY, Flanges • supports • mounts • brackets • hinges
