The VLT Micro Drive is a general purpose drive designed for rugged and reliable, out-of-the-box, plug-and-play control of AC motors up to 3 hp. Later this year, range will be extended through 10 hp.
Suitable for use in industrial appliance, water, and HVAC applications, as well as to OEM machine builders, the drive eliminates an external controller. It also gives side-by-side mounting capability without de-rating because of its compact design.
It comes in cabinet sizes as small as 2.75 in. wide x 6 in. tall x 6 in. deep. Approximately 100 parameters can be set to optimize energy efficiency and operation. A “flying start” feature provides more uptime while an electronic thermal relay eliminates the need for external motor protection.
The VLT Micro Drive also has a smart logic controller, which integrates the drive and motor, allowing users to program the controller to react on virtually any event, often eliminating the need for a PLC.
The drives come in single-phase 200 to 240 Vac: 1/4 to 2 hp; three-phase 200 to 240 Vac: 1/3 to 2 hp; and three-phase 380 to 480 Vac: 1/2 to 3 hp configurations.
Danfoss Drives
4401 N. Bell School Road
Loves Park, IL 61111
Tel: 800-432-6367
Fax: 815-639-8000
Email: [email protected]
Web: www.namc.danfoss.com
About Danfoss
Danfoss is a leading manufacturer of precision mechanical and electrical components, with locations in more than 120 countries. Danfoss created the VLT name when they introduced the world’s first mass-produced VFD in 1968, and the name has set the standard for high performance quality variable frequency drives ever since.
:: Design World ::
Filed Under: Appliance engineering + home automation, Drives (servo) + amplifiers, Motion control • motor controls
