Flexible CT Couplings are especially well-suited for industrial uses. This type of coupling is virtually failure-free and is an optimal and cost-effective solution for many applications. Elastomer elements under pressure provide a damping effect.
CT Couplings dampen torsional vibrations and shock loads in the driveline. In addition, the coupling balances axial and radial displacements. This increases the operational stability and service life of your equipment or system, which in turn increases the availability and reduces the total cost of ownership.
Models with plug-in connections for bell-house installation are optional.
Typical applications: generator sets, crusher, mills, shredders, general industry.
Voith
voith.com
Filed Under: Coupling Tips
