These universal joint shafts are of modular design and can be easily integrated into your drives. The flange connections are available in friction and positive locking designs. The R-series have been optimized using FEM. High-strength tempered and case-hardened steels and center sections with a large diameter serve to reduce the weight. At the same time, the bending and torsion rigidity is increased. As a result, the universal joint shaft is highly efficient in operation and less sensitive to vibration stress.
Torques with a single load MZ
Up to 1000 kNm
Deflection angle
Up to 25°
Torques with a reversing load MDW
Up to 500 kNm
Rotation diameter of the joints
198 mm to 550 mm
Centre section
Steel carbon fiber-reinforced polymer (CFRP)
Connections:
* Friction flanges
* Flanges with face key
* Flanges with Hirth serrations
* Flanges with split sleeves
* Quick-release couplings
* Adapters
Voith
voith.com/corp-en/index
Filed Under: Coupling Tips
