Ensuring continuous production, the SlipSet is designed to slip in the event of an overload situation. Acting as a shock absorber in drivelines with frequent torque peaks, this torque-limiting coupling safely prevents time-consuming repair work and shutdowns. This coupling is compact in design and can be installed in areas with limited space; this ensures optimal positioning in the driveline. The SlipSet torque limiting coupling is ideally suited for applications requiring short peak loads (smaller than slip angle 120°).
In a temporary torque overload, the coupling slips to limit the torque peaks and enables continuous production. If the blockage persists, the SlipSet coupling slips until the drive can be stopped for the obstruction to be cleared. To monitor the maximum slip angle possible, we recommend using the Dtect torque system.m.
Voith
voith.com/corp-en/products-services
Filed Under: Coupling Tips
